Civrel
I am relocating my water pump and softener out of the elements from the back of my house to an adjacent shed. When my house was built 34 years ago, the plumber ran the soft copper pipe under the form boards, but still through the concrete footer. The soft copper was encased in poly pipe to protect it from the concrete. The pipe was bent vertical after emerging from under the footer and points straight up.
My current plans are to add a deck where the pump and softener slab was located, but the copper pipe sticks up higher than the deck surface. I really didn't want the copper (and PVC fittings that will make the new connection) sticking above the deck. My options would be to cut copper shorter, but I worry about being able to solder a new fitting on that old of a pipe or the best solution would e to bend the copper pipe horizontal, lowering it below the deck and burying the copper/pvc connection. Both of these solutions would end up with a buried solution. What are my chances of bending that old of a pipe without breaking it or cleaning it up enough to solder a new fitting on the end after I cut it off? I attached a photo of the pipe. Anyone have any other suggestions or advice? For clarification, the slab in the rear right of the photo is the one that the deck will be level with, not the slab to the left. Thanks!
