Greg Lovern
I have a Lennox furnace that was installed probably in the early 1980s. It has an intermittent pilot light.
Normally when it's trying to ignite, if I'm standing next to the furnace I hear a repetitive clicking sound; several clicks per second. Then I hear a whoosh as the pilot light ignites, the clicking sounds stops, and soon the burners start up and the fan starts.
This year, when we first tried to get heat, cold air blew from the vents. I saw that the burners weren't lit, so I turned the furnace off, set the thermostat to a high temperature, and turned the furnace back on. A small motorized door that seems to regulate how much air gets to the burners closed when I turned the furnace off and reopened when I turned it back on.
But then, no clicking sound as I would normally hear at that point. After a while an indicator light on the electronics unit started flashing 1 second on, 5 seconds off, repeatedly.
I repeated several times, always getting the same result. I started unscrewing a panel to try to get access to the ignitor and pilot light to investigate. I had to leave for a while and when I came back to it the next day, I once again tried cycling it. This time I DID hear the clicking. And then the whoosh of the pilot light. and then the burners came on and it started blowing warm air.
So for now all is well, but since I did not actually do anything I assume it's probably going to happen again, perhaps soon. But of course it's difficult to troubleshoot a system that's working properly at the moment.
So my question is, what are your guesses as to what the problem might be? Is there anything I can check while the system is working properly?
Also, followup question -- can a furnace like this be upgraded to a hot surface ignitor at a reasonable cost?
Thanks,
Greg
Thanks,
Greg
