NoLeak
Hello,
Need to install new closet flange on old 1936 4" Cast Iron pipe. Original plan was to install a Sioux Chief Push Tite gasket flange 886 GA, so I can set to proper height on top of new tile install. A local store should have it in stock in a couple of days. However, I'm not sure it will work now as the bend in the pipe starts almost immediately, so I'm worried the bottom gasket won't seal properly. I've read on their site that it can be cut, and extended if needed. So, I was thinking then maybe ok to also cut and shorten? Then slide the gasket up? The top of the pipe is currently 1/2" below new 1 inch hex tile and 1/4" hardibacker. Any problems with this I'm not thinking of?
Another plan, I could remove a bit of the tile and hardie around the pipe to accommodate a new CI or brass flange that will slip over the outside like the old damaged one I had to remove. I don't have lead soldering tools, ladle, etc. and am on a bit of a budget. I've heard some have had good results using Hercules Plastic Seal in place of traditional lead and oakum. Below is YouTube video, only difference seems is he has lead bend instead of CI and forms with hammer. Think this might be better route? Brass or CI flange better?
Lastly, I will be installing a Toto Vespin ii toilet. Thin 1/8" hex tile, 1/4" hardie, with about 1" ply under that. Should I use the suggested cement/tile install anchors screws for the unifit, or different method better for my setup?
Really appreciate the advice.
