Could you recommend where to get inlet and drain valves (1/2" 12VDC normally closed brass valves)?
The valve must have an integral bracket (see picture). That bracket gets attached to the steam generator case with two screws, which prevents rotation of the valve when a pipe coupling gets screwed in.
Such valves are used in Saunacore Steamcore and possibly SteamSpa steam generators.
Thank you.
Thank you.
