This is a brand new 48000 grain unit replacing a 25 year old Kenmore Genius. I sized the unit based upon the water being pretty hard and for future use with more people in the household.
There is a wealth of information in this forum regarding programming but the more I read the more I am unsure what changes I should make, if any, from the manual recommendations.
I have city water. I have tested the water and hardness is around 400 ppm (23-24 gpg). Iron is relatively low around .05. Right now just one person in the household but looking at water usage over the several months it is averaging only about 45-50 gallons per day.
The first setting is asking for gallons used to trigger treatment. In their example they use the marketed capacity divided by the hardness then subtracting household gallons used. I have been reading that in some cases using the marketed capacity is not advised due to the amount of salt required to achieve.
So some of the confusion begins. I thought I should use something closer to 30000 true capacity which would give pretty close to 1300 gallons. At that rate it seems it is almost a month between regenerations. Maybe that is ok.
Then comes the rest of the uncertainty regarding default values for back wash (15), brine time (60), rapid rinse (10), and water fill (12).
Any input on these values would be greatly appreciated.
