NebraskANN
... isn't going as well as might be expected. Who knew there was so much to learn about basket strainer drains? I'm sure you did, but I was surprised.
I read about three dozen reviews of the various basket strainer drains at Home Depot and finally found one that everyone seems to like. It's substantial, in terms of weight and construction, doesn't leak when you want to hold water in the sink, and the notches in the strainer are sufficient to hold it up when you do want the water to drain. It won't corrode and it does come with instructions.
The new problem is the PVC slip-joint extension tube that I was going to order to connect to the drain. All the reviews are terrible. It seems like there are quality-control issues. The washers are flimsy and don't do much to provide a good connection, so they seem to leak quite often. Would a metal tube work better, and can I connect a metal tube to a PVC J-section to create a trap? Would it be better to use a metal J-section, and could I connect that to my existing PVC? At some point, I'm going to have to cut a pipe to fit what's already there. I have a hacksaw. I have no idea how to cut a metal pipe.
I hate to impose a second time, but could you offer some advice on my pipes? Thank you. -- Ann
