Maximum pressure limit for steam boilers
Atit Koonsrisuk
Thailand
Dear all,
I was wondering if there is a code or law that limit a maximum pressure for boilers used in steam power plants. Or we can design a steam boiler as large as we want! If there are such codes, please inform me.
Thank you very much.
NY_Rob
New York
If you're the designer and don't know the local codes... good luck to you!
Sylvan
Still learning
New York
ASME . NBBI are great sources to start
A high pressure boiler (steam) is 15 # or higher
I was a boiler tender and the boiler we operated at was 1,500 PSI superheated steam
So depending on the applications what volume of steam and the pressures are required
Atit Koonsrisuk
Thailand
Thank you for all kind responses. I am not a boiler designer. I am trying to compute an optimal capacity of a boiler that provides a maximum performance for my available heat source. So I would like to know the limit of the pressure that I can choose.
Best regards,
