Long Sweep 90 or 1/8 / Wye Combo
Nate R
Milwaukee, WI
If I'm going vertical to horizontal, I don't need to use a 1/8 / Wye combo if the horizontal line doesn't extend behind the vertical drop, correct?
As in, a long sweep 90 is OK in the attached diagram in black? But if the horizontal line was longer (The blue line) THEN I would need to use a combo?
Mikept
DIY Senior Member
CT
are two 1/8's together longer than a long sweep 1/4?
Krow
Ontario, Canada
I hard a hard time understanding your question at first. . you can use a 1/4 bend or 90 if the horizontal does not extend to your blue line. If it goes into the blue line then a Y and 1/8 bend (45) combo is needed
yes they are
BAPlumber
Vashon, Washington
if you are going vertical to horizontal you should use either a long turn 90 or combo (wye and 45), whichever is appropriate
fitting
Unless the line is continuing past where the connection is made, there is no need for a Y, combo, or any other fitting other than a long radius 90 or two 45's. Therefore the question is irrelevent.
jeffrandi
Follow up question:
Do the above response hold true if the fixture is a water closet at the top of the vertical section (or does a WC have to be at the end of a section)?
Nate R
Milwaukee, WI
Well, I don't know the answer to the WC question. I'm sure a pro will know.
Here's what I was asking about, except now it's about done. :D
Everything after the 1/8th/Wye combo is temporary. In about a month when I'm done with the bathroom and then working on the kitchen and tearing into walls, the pipe will turn right instead of going down.
I also need to fix the hanger situation, I know.
pipe
As long as the toilet is vented it does not make any difference where it is connected. I am not sure what you mean when you say it "will turn right instead of going down", unless you mean it will continue going straight to the right.
Nate R
Milwaukee, WI
The obstacle on the right is a chimney. Instead of going behind it as it does now, it will go around the other side once I open up the wall on that side.
