Leaking bath faucet
Southern Man
DIY Hillbilly
North Carolina
This one's got me stumped.
This is the last of the Moen bath faucets in the house that I have occupied for over 11 years. I've had to replace all of them except this one. It's in a basement 1/2 bath and drains to a grinder pump that only serves that bathroom, pumping up to the public sewer.
The pump float was hanging up so I shook the vent pipe to cycle it, then ran cold water from the faucet for 2 hours to clean out the sump, checking on it about every 15 minutes. I could also hear the pump cycling as normal during this time. On my last check there was water on the floor so I shut off the faucet, cleaned up the water (the vanity floor was soaked). I found the leak coming from the hole in the vanity top, down the stop operator rod.
The leak stops when I turn off the faucet, and runs 2 or 3 drops per second when I turn on the hot or cold water.
Where could the leak possibly be coming from?
leak
The most common place is that aerator is sending water back inside that sheet metal cover plate,and then it leaks through the center hole under the faucet.
Southern Man
DIY Hillbilly
North Carolina
Bingo- that was it! I cleaned out the aerator, checked the gasket (which was fine) and had to tighten it in with pump pliers to get the leak to stop, but it did. Thanks!
Southern Man
DIY Hillbilly
North Carolina
Unlike certain people who think they know everything, yet obviously don't, I continue to learn every day. I've learned as much from guys with dirty fingernails as from academic types. :)
Redwood
Ah Grasshopper just when we thought you were impossible to teach, you contradict yourself....
Redwood
Until now!
re the link
And another thing to consider is that phone call routed through a satellite travels the same distance whether it is going next door or across the country, but you pay differently for the calls.
Southern Man
DIY Hillbilly
North Carolina
A friend of mine used to say that since you paid a much higher price per pound of propane to fill a 20# bottle than if you paid for a 300 gallon delivery, that it proved that the gas costs the propane company essentially nothing.
