Hi all,
First time poster. I had to get a little creative with plumbing the kitchen sink after replacing the counter-top and sink this weekend. A picture of my solution is below. Is there anything I should be concerned about with this set-up? The sinks and dishwasher appear to drain fine. Any code infractions here?
The height/location of the waste pipe to the wall is horrible (1950's house, has 1 1/2 inch copper waste-pipe through the wall and behind the cabinents - the waste pipe is high and also is situated directly below the left sink). I do not want to move the waste-pipe. I did not re-install the garbage disposal because the outlet would be 1-2" lower than the wastepipe.
Without a disposal, I had to drain the dishwasher straight to the drain pipe. I wanted it to drain above the p-trap so I put in a 4-way connector and used a dishwasher connection at the top (which is capped).
I know there is quite a bit of water that will sit in the pipe between the wastepipe and the 4-way connector. Is this an issue?
Thank you all for any advice.
