Kitchen faucet nut won't budge for removal
learning
MD
I'm having an impossible time removing a 16-year-old Moen M7800 kitchen faucet. It's to be completely replaced, so it doesn't matter if it gets damaged in the process.
Here's the main problem: rather than there being three lines (hot, cold, spray) that run through the central hole in the sink, there is a one central copper threaded line, with copper pipe extensions for all three connections soldered to the base of that.
So there is only one rather large fixture attaching it to the underside of the sink, with a single metal washer and nut. The nut is about 1 3/8 - 1.5 inches diameter, and due to it's size, a basin wrench won't go around it. Due to it's age, it's corroded. It's in behind the center of a double sink, and hard to get a good grip with enough force with anything large enough to go around the nut.
My local big box hardware store suggested spraying it with PB Blaster and giving it a go, even whacking it with a hammer to loosen it. I've done all that, but with no luck so far.
Oh, the garbage disposal is out, so there is a bit more room to move around under there. It's being replaced too, so it's gone so I could get at the faucet.
If I could just get this nut off, I could be on with the rest of the project! Has anyone else run into this? Thank you for any advice and suggestions.
That doesn't look that corroded. There are basin wrenches, and then there are basin wrenches.
MACPLUMB
HOUSTON, TEXAS
You need a ridgid # 1017 basin wrench that will take it right off !
They are made much heavy-er duty then the cheap you might buy at a hardware store
Jimbo
San Diego, CA
The neat way is to cut the nut with a dremel. I like to use a cold chisel. The nut will either turn, or split. It takes some "touch" because you don't want to damage the sink. I have done it often, with no accidents.
learning
MD
Comforting to hear someone more experienced refer to it as not that corroded. (Pic was taken after 2 applications of PB Blaster, which did help some.) Excellent point about the basin wrenches. The ones I've seen around here (so far) are the smaller ones meant for water line connections, so I'll have to keep looking.
learning
MD
@jay_wat: if only I had one that size…
@MACPLUMB 777: Thank you so much for pointing me in the right direction for what to look for. Very helpful, as the ones I keep finding are pretty "cheap" feeling.
@jimbo: I tried something similar to the chisel method you describe, with a flat-head screwdriver and a hammer, which obviously doesn't have the heft and force of impact a good chisel does. Great idea with the dremel. I might be able to borrow one; will have to do some calling in the morning.
Thanks, everyone, for sharing your expertise with me!
Jimbo
San Diego, CA
Comforting to hear someone more experienced refer to it as not that corroded. .
I guess what was meant was "if you want to see corroded, you should have seen the monster over at Mrs. Smith's house!" Sort of plumber's wives tales!
faucet
Even if you get it "loose" you will have a problem unless you have someone to hold the top while you struggle with the nut. Use a drill bit and drill on both sides of the nut. It will then "fall off".
The new faucet.
It would not serve any purpose to put TPFE tape on the thread.
Tape is the most misused product in plumbing. So many times when I get called out for a leak, it's just a matter of removing tape that should have never been used. It's very rare for any DIY or homeowner plumbing that would ever need tape.
Flex supply lines for faucets? They come with seals on the ends already.
Water heater flex? They also come with seals.
Bathtub drains? The seal is made with the rubber washer between the shoe and the tub.
Compression stops? Nope, the seal is made with the ferrule.
Straight threads don't need tape, it sometimes prevents the nut from threading up all the way.
You can use tape on tapered threaded pipe if you are threading on a fitting. A thing that a homeowner will almost never do.
Koa
Honolulu, Hawaii
Drilling with long bit is probably easiest since Dremel might not fit. Wear eye protection. If you can get some sort of wrench on it but no room to turn it, try unscrewing faucet from top. You might have to disassemble it a bit depending on design to get a grip on a non rotating part.
