Is trap too close to heat pipe
greg_xyz_nj
Morris County, NJ
bathroom remodel.
changed tub location and drain location changed as well.
contractor said this is ok. I'm skeptical.
The copper pipe is the water line for the hot water baseboard heat in the bathroom.
any thoughts?
WorthFlorida
Solutions
Orlando, Florida
PVC melting point is 140 degrees. Hot water should not be more than 120 degrees. As long as it does the two do not touch each other, it is OK.
So Ive never worked on residential heating hot water greg I think you should verify the temp of the water My guess there will be insulation on the pipe as well
