Is there a plumbers dye?
DIYourselfer
Philippines
Trying to find a leak in bathroom. Is there a dye that the pros use that won't stain a tub? If I use a dye in the tub water then I will know when I see the dyed water on the unfinished ceiling below that it is probably the drain, not the pipes or mixing valve.
Thanks!!!
If the leak stops, then it is NOT the pipes. There are easier ways to isolate whether it is the valve or drain, and a plumber would know how to do it.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I remember many years ago, the septic field police were going around to homes and flushing a packet of dye down the toilet. Then they would walk around the property looking for the dye to break to the surface or enter a stream.
