Is it normal for water pressure to fluctuate when no water is running?
GL77
Washington
I have an undersink water filter that has plastic tubing lines that jerk just a little when water has turned on or off in the house or yard, just so you hear them creak and you know water pressure has changed. Today I've been around the house all day and I have been hearing them doing that frequently throughout the day when I'm not running any water. My outdoor spigots are still closed off for the winter. The toilet's not running. I haven't done laundry or run the dishwasher. Single family home on city water. I don't have a PRV, pressure is fine without one. I'm just curious what would be causing these pressure fluctuations? Does it affect my water pressure when my neighbors run their water? I'm just curious. Is it normal?
In a perfect world you dont get noticeable spikes or hear your water pipes moving. but what you describe sounds relatively normal. Generally a neighbor flushing a toilet goes un noticed a block away or even next door.
John Gayewski
Iowa
Plastic pipe can be pretty sensitive. Maybe a 1psi variance from time to time would be normal.
GL77
Washington
What type of water filter? Do you have an ice maker in the refrigerator?
I have an Apec 3 stage filter that goes to a drinking water faucet at my sink. It's really nice. I have tons of sediment in my water and it comes out the filter clear, albeit full of bubbles. I disconnected my ice maker in the refrigerator because I never use it.
GL77
Washington
Thanks, I figured it was probably normal pressure variations. If it weren't for the sound the plastic tubing makes, I'd never be aware of it. It's weird to think of though. Plumbing is so interesting.
water dosent "Give" much when contained in a pipe its almost like steel think of your hydrolic brakes on a car no matter how long that brake line is if you push fluid on one end a reaction will occur
