installing icemaker box
Hardman
N. Little Rock, AR
I am installing an icemaker box - the existing water line is 1/4" OD copper. The icemaker box requires 1/2" copper. Any problems using a 1/4" to 1/2" coupling from the existing line to the box?
box
Is that 1/4" line inside the wall? I have never seen a plumber run anything other than the proper 1/2" pipe INSIDE the wall. 1/4" is normally only run outside the wall from the sink.
Hardman
N. Little Rock, AR
icemaker box
It was an existing line dropped out of the attic through a cabinet and down the outside of the wall by a previous homeowner. I am remodling my kitchen and have moved the refridgerator to an oppisite wall. I just moved the 1/4" line over and dropped it inside the wall to clean things up. Thanks both of you for your help.
