Thanks Bannerman
The 7.5 was a typo.
BF is set to 7 min.
This started because it looked like a lot more water in Brine tank than the 5 gals I originally put in tank for first Regeneration.
That's the water level after 1st Regen (80 lbs of salt minus 1 regen)
That led you to recommend I look at the BLFC.
I couldn't get the retainer clip out but could see a BLFC.
I had the bright idea to measure the amount of water going into the Brine tank to confirm the correct BLFC was installed.
I disconnected the Brine tube from the tank to confirm I could get it out.
Reconnected the tube, ran a manual Regen and that's when the unit failed to suck the Brine out of the tank.
I bet I introduced an air leak when I reattached the hose the first time.
The connection inside the Brine well looks to be the weak link in this system.
I don't Like those push to connect fittings.
I will make sure the connection is solid and run another Regen tonight.
Hopefully it will suck down to the Air gap like it did the first time.
Should I look at replacing the whole assembly in the Brine well?
Will the holes line up?
What do you think of the water level now that we know how much water is being pumped in?
