Identifying issues with installing freestanding tub in basement
Queen50
Auburn, Washington
Need advice, please. We want to replace an acrylic one-piece shower with a freestanding tub in a basement bathroom. By removing an alcove wall and rerouting the pex water lines, we would have the space to place the tub utilizing the existing drain. (The drain lines are below grade.) The work would be done by a professional plumber.
Is this a viable option? What are the pitfalls?
CountryBumkin
Active Member
Orlando, FL
Sounds reasonable. The issue you may run into is whether or not there is enough drain pipe available (above the concrete) to attach (glue on, assuming your working with PVC or ABS pipe) the proper coupler for the tub's drain pipe to connect to. If the old shower base is removed and the drain pipe ends up flush to (or below) the concrete your going to need to chip away some concrete.
The new free standing tubs make for an interesting install.
The fill valve for some are independent and may need to be suppled with water from the slab. A lot depends on the brand of faucet you working with.
Draining the tub, may or may not be somewhat exposed depending on your tub.
Keep in mind, there is no going underneath to make a final connection. I did one tub where we left a hole in the kichen ceiling below and then had drywall done to fix the ceiling.
Queen50
Auburn, Washington
Thanks for the info. I thought some of the slab might need to come up. Looking at the faucets available, it looks like the pex water lines will need to be run under the slab as well. Oh, well.
