Ideas on pulling Rugged from that chimney
Herk
S.E. Idaho
Construct30 said:
Have you ever been snaking a clogged drain and had someone flush a toilet on the second floor, and I'm talking an old style high volume one?
Usually, it's while I'm replacing a section of 4" cast iron. It doesn't matter if you tell them not to use the plumbing - they forget.
Herk
S.E. Idaho
I've had a lot of discussions about "hot water heaters." I always say that it heats cold water, so it's a cold water heater.
Construct30
NorthWest PA
I was looking down the "CLEANOUT THINGIE", never look down the pipe while you're snaking a plugged drain. No one was living there, it was one of the guys working with me. I sat next to him at lunch.
Cass
Well kids I'll tell you what to do with toilets...
I first flush all toilets with the stop closed then Duct/Duck Tape the seat closed, takes all of 2 min. and prevents the big problem.
They are paying for my time...so they pay for me not to get covered with...
Markts30
Commercial Plumber
Phoenix, AZ
Add a recirc line to the hot water system...
The returning water is no longer cold...
Presto - a Warm water heater????
water heater
It is a COLD water heater up to the point where the water is hotter than the incoming water, then it becomes a WARM water heater, and finally a HOT water heater, just before it shuts off.
Cass
Yes, but its main function is to heat water so it is a water heater.
Most people in offices gather around the water cooler.
Construct30
NorthWest PA
Where's the sport in that?
I love cutting into a main line and having to help a few logs along while you work. We have to cut they won't let us saddle.
GrumpyPlumber
Licensed Grump
Licensed Grump
Then there's the "You don't use gloves when ya do that?!?!?"...yup, flip those gaskets with gloves on so you can slide the piece in...give me a holler when yer done.
Cookie
Home
Um, you do get the immunizations for Hepatitis, right? Please say you do, if you don't, you should.
Cookie
Home
http://www.heptrec.org/faqs.asp
I wonder if maybe, a survey could be put to a good use here asking how many plumbers do get immunized. You got to realize this disease can be spread to your loved ones.
