hotwater versus steam
Chicago
What is the difference between a radiator shutoff for a steam system, versus a hotwater system? I've been told that a hotwater shutoff has a small pinhole in the rubber gasket, and the other doesn't. Is this true, and if so what is the hole for?
Thanks very much...
Finnegan
CT
Where is the valve located? I am not sure what you mean by "radiator shutoff?
valve
The steam valve has a rising stem with a composition gasket, not rubber, on the end of it. It will turn off completely. The hot water valve has a rotating sleeve, not a stem, and it does have a small hole in it to maintain some circulation even when shut off.
Chicago
Thanks HJ,
I guess that they really are different, even though they look quite the same except for the hole. Then they can not be used interchangably, right?
