Moved into house with Kohler mixing valve in shower. Fixture is approximately 20 years old. This is a one handle mixing valve. Pull out to turn on water; clock wise for cold; counter clock wise for hot. Handle is pentagon shaped, clear plastic, with pentagon shaped screw cover. PROBLEM: The water temp flow is opposite of the markings on the handle. Clock wise produces HOT and vice versa. I have taken the mixing valve apart three times. Everything appears to be keyed such that alternative assembly is not possible. Am I missing something in the assembly, or is this thing simply piped backwards?
Thanks, GDM
Thanks, GDM
