Help with my toilet plumbing design
Didymus21
Portland, Oregon
Hi all,
So I moved my toilet from one area of the bathroom to another. Everything drains into a vertical stack that goes up through the roof. I'm trying to figure out the best approach for draining the toilet back to this stack.
Here is the stack:
This picture shows approximate distance from the center of the new toilet drain hole and the center of the old fitting.
I'm thinking I'll need to do a 90 deg long sweep elbow off the toilet flange as well as off the vertical stack. Then find a way to snake down to the old fitting. I'm just not positive how to best get that done, or if that is the correct approach.
Feedback appreciated.
Didymus21
Portland, Oregon
Two sweep 90's would over shoot.
Would it be best to do 90 off the stack, then another 90 toward the flange, then maybe a 45 off the flange?
we are not there, so we are just guessing, but a long sweep 90 RIGHT IN FRONT of the tee, with a horizontal line into a 45 pointing to the new location with a closet bend 90 up to the toilet seems like the most likely paty.
