Koches
Greetings,
Due to a bad bladder, I am installing a new pressure tank (Amtrol WX-202) and taking the opportunity to relocate it from the well pit outside to inside the basement.
Knowing that the pressure switch should be as close to the tank as possible and most commonly placed on a top port of the tee assembly, I do not understand how to properly move the new switch inside because the current switch is attached to the well pump (Goulds J5S) and is fed from just 1 wire which is connected into a box (junction?) containing a wire that runs to the electric panel inside the house.
Please see picture and let me know your thoughts.
Thanks in advance.
Brian
Thanks in advance.
Brian
