Help Identify this shower valve
Rocknroj
Washington
I have the wall open and am looking at the back of this thing. Not sure what kind of valve body this is nor have I seen the type of connection. Some plastic with a crimp attached to a sweated in stub. The thing is flopping around. It has a single lever that when turned on starts hot and the further I turn it gets colder. So reversed I guess.. Viewed from the back the hot line is on the left.. Here's a picture of the back of the valve. Any help appreciated.. Thanks in advance
It's a Moen Posi-Temp.
The cartridge can be rotated 180 and that will allow it to start off cold and then rotate to hot, which will be more volume than you had with the reversed hot and cold that you've had.
Takes the 1222 cartridge.
Rocknroj
Washington
Thanks for the info... Loads of help!
What kind of connection did they make to the shower head and supply lines? I have never seen it before and no luck searching the net. Looks like an adapter sweated to the valve with some sort of crimp connected vinyl supply line. Same thing in the original copper coming up the wall.
Tuttles Revenge
The color is sorta hard to tell in the photo, but if its white/opaque then its just PEX with a viega style crimp. If its a gray tube, then likely its PEXAlPEX which is a layer of aluminum sandwiched between PEX layers.
Rocknroj
Washington
It more opaque white.. so that would be PEX B fitting, and not compatible with the expansion type PEX that I am used to working with correct?
I will pull the trim today and see if I can get a better look at the valve from the front side.
thanks again
GrumpyPlumber
Licensed Grump
Licensed Grump
I'm "kinda" sure that's a crimp fitting sold by HD or Lowes that was a precursor to the copper crimps they sell now, it's one of two types of crimps.
Tuttles Revenge
Its a Viega fitting. You can see the "window" cut in the crimp that indicates that the tube was inserted fully.
We just sold a bunch of these fittings back to one of our suppliers.
