Jackblacus
Greetings,
I live in Queens NY and currently have a Weil Mclain Series 6 CGM-7 210,000 BTU boiler. I have owned my house for the last three years. I don't know how old the boiler is, however a service tag attached dates back to 1997. Heating bills are very high in NYC and cost 500+ a month in winter which is what got me doing research on boilers. The house is an old Victorian, however R19 insulation has been added to all exterior walls and new modern doors and windows replaced on all.
Currently I have a old Gravity system with cast iron rads which was converted with the addition of a Bell & Gossett circ pump series 100. I have cast iron rads with a total EDR of 892. The house three stories, has an unfinished basement, two living floors, and a finished attic with heat rads in all locations. Total square footage of house is 3100 sq feet. Rads get to about 100-110 degrees with FLIR.
I was doing research into new Con/Mod HE boilers when I realized that this boiler has, ALWAYS?, been condensing which is bad for corrosion. The boiler heats the house well running for about 30 minutes between cycles of 1.5 to 2 hours depending on temps in December, in colder months longer. I used a FLIR ONE recently with electrical tape (for reading accurately) on the supply and return pipes. With 30 minutes of run time the temps are 110, 100 return. With run times of an hour the temps are 120, 110. I have never seen the temps approach 140 or above, but also I haven’t checked the pipes in January/February.
There is NO temperature return mitigation on this boiler, clearly being plumed incorrectly. Even the original manual for installation talks about return mitigation.
My questions are, why hasn’t this boiler failed after so many years of usage in this configuration? And can anyone suggest a new boiler for a converted gravity system for this house.
Thank you in advance. PHOTOS attached. https://www.flickr.com/photos/197086861@N02
