Glued-In Sink Plumbing
MisterJJ
Durham, NC
I ripped out an old bathroom sink to replace with new and I found that the previous owner glued the drain line in place and now there's no room to cut it off and add a proper connection so I can position the p-trap correctly. Any ideas on how best to fix this?
If there is space between the coupling and santee cut it off remove escutcheon and glue another coupling on . otherwise you need to remove pipe from hub . there has been several postings lately on how to remove a glue in pipe from fitting .
Or a trap adapter and that way it's easily removed when you need to remove it to clean the trap.
MisterJJ
Durham, NC
Not enough space between coupling and wall to get glue in a fitting with full insertion. But I could probably get enough to work. I hate doing things half-arsed like that though.
I didn't see any obvious posts about removing glue in pipe. How the heck do you remove a solvent welded fitting? I did some googling and found an ABS reamer, which seems like it would work. Kinda expensive for something I would likely use once.
Skoronesa
East Bumfuk, Mississippi
..... I did some googling and found an ABS reamer, which seems like it would work. Kinda expensive for something I would likely use once.
They make cheaper(less than 100$) versions but they really aren't good. The most foolproof way(without opening the wall) is to get a good reamer. Old ABS gets brittle and the reamers can catch and crack it. Or you could go the very pedantic route of grinding it out/off with a dremel.
Skoronesa
If it's going to be inside a vanity and you can't patch drywall just cut open the wall, replace the tee in the wall and stub out a new piece, and then put a painted piece of plywood over the whole thing. Technically it should be fireproof so you could do a piece of sheetmetal or drywall.
That's why I am a plumber and not a painter/drywaller ;)
I used thin prefinished flooring planks that were made for a floating floor. By having the planks that interlocked, I could cut and screw the pieces in. It was easier to clear the supply lines and trap adapter more easily. The finish was selected to be similar to the inside of the cabinet.
They make cheaper(less than 100$) versions but they really aren't good. The most foolproof way(without opening the wall) is to get a good reamer. Old abs gets brittle and the reamers can catch and crack it. Or you could go the very pedantic route of grinding it out/off with a dremel.
MRjj I was thinking you could cut it right at coupling and scrape around the drywall so you would get full insertion, wasn't talking about only partial engagement. pretty easy job more than one way to do it. you've got all the options let us know how it works out.
MisterJJ
Durham, NC
I didn't really think about just digging into the wall. With my luck, the T connection will be right behind the escutcheon (that's a weird word). But if so I could just cut away the wall and do what needs to be done. Thanks for the idea.
you gain 1/4 inch just removing escutcheon im just looking at a picture but it looks pretty close to having full depth
