My husband and I just bought a 100 yr old house and are doing a ton of work ourselves. Most of the windows are being replaced by professionals, but there were two windows in the back addition we wanted to save money on, b/c we didn't need to save the original trim, didn't need to keep original dimensions, etc. We got some salvaged replacement windows, took out the original frames/windows (they were rotten), and my husband framed out new openings for the salvaged windows. I've read that the only real difference b/n replacement windows and new construction windows is the nail fin. Is this true? We want to make sure that we do the flashing correctly, and are also perplexed if a windowsill is needed for any reason if we use flashing and caulk, etc. The vinyl siding is off, and we will re-side, so working around existing siding isn't an issue (though trimming the window properly once we start siding is).
My questions are:
1. Are we crazy for framing out a space for a replacement window? Is a new construction window our only option? I'm just not seeing any info online about this. My husband is handy at problem solving, framing out new walls, and other basic carpentry things. This is just a new area of challenge for us. The new windows are in - at least temporarily, and they didn't leak when it rained.
2. How should we install flashing properly? Is there a site you can point us to? I've found it for new construction windows, but didn't know if we should do something different in our situation.
3. Do we need a window sill or can the window be flush to the outside, as long as flashing is directing the water away from the wood - ie maybe over the house wrap?
Thanks for any input you can give!
My questions are:
