Fleck 9100 Timer ID
sarrowsm
F5Scott
Brighton, MI
Please help ID this Fleck Timer on 9100 Control Valve?
Thank you,
Scott
Akpsdvan
Alaska
It is the 3200 timer run from Fleck, the one that you have does not have time, but rather gallons to trip it from one tank to the next.
The frame that the parts are on is the same frame that is used for the timer one that will delay in gallon or day time trip..
Set the gallons across from the white dot much like your old one.. if your old one was at 800 gallons then find the 8 on this one and set with the white dot..
Old Fart
Mi
Pentair makes Fleck and Autotrol valves. PentairWaterTreatment.com, click on Fleck control valves. On the right side of the page, under Residential, is a list of Fleck & Autotrol valves. Click on a model number and it takes you to the spec sheets and the service manuals.
I have about worn this sit out over the last week or two. Hope this helps.
