Jerod Mickelson
I had a plumber out here to convert piping from a single vanity to a double vanity. He capped the ends and a week later I am now installing the vanity and faucets.
First snag I am running into is he used a 1 1/2 inch threaded male connector. (1st Photo) The p trap I used for a faucet was 1 1/4 inch. I went to Home Depot and was able to used to different connections to be able to make it work (2nd photo). Well it worked for one.
The second lined up directly behind the drain and there is not enough room to make the connections (3rd Photo), photo also shows that the 1 1/4 doesn't fit.
If I try to use the connection from Home Depot, the P trap then doesn't fit (4th Photo)
If there was a smaller connector, I believe there might be enough room (example 5th Photo), just don't know what that connector is
Last Photo is the connector that work on the other sink because they were not lined up
Any help would be appreciated
