No. While they should, many sellers skip it to save the 15 pounds of shipping. I wouldn't think Kinetico would skip the gravel.. Do all tanks contain gravel at the bottom?
If you have gravel and could re-claim the old gravel, no need for new.Should it be replaced during a resin change?
Why are you changing resin? City water chlorination degrades resin, so I suspect that.
Since 'K' brand softeners typically utilize small resin tanks, I anticipate they will not be normally equipped with any gravel as gravel will displace resin and will therefore reduce the quantity of resin contained in each tank.
Are you experiencing excessive hardness before the system switches over to the alternate tank? Is there a noticeable flow restriction when water flow is through the softener that becomes less when the softener is bypassed? Is your water source a private well, or is it a municipal supply that will be chlorinated?
While that brand utilizes innovative methods and good quality equipment, they are seldom recommended on this forum, mainly due to reliance on their closed dealer network to obtain parts and service. Their turbine driven valves are also complex and so repairs or rebuilding is usually not a straightforward DIY project for an average system owner.
The brands of control valves most recommended on this forum are either Fleck or Clack. Fleck and Clack do not build or market softeners as that is performed by their dealers utilizing various off the shelf components.Which water softeners are normally recommended?
No. Why is that a concern?Are there any recommendations on non electric units?
I've noticed the water doesn't have suds like it used to. Also, I've noticed more iron. I haven't noticed any restrictions in water volume. I'm on well water. The kinetico reps seem to be very inexperienced that they send out. The last guy basically said he doesn't want to guess what is wrong with it, so he is recommending a rebuild or new system. It seems like they always recommend a resin change. They are the only Kinetico dealer I can find.
Which water softeners are normally recommended? Are there any recommendations on non electric units?
