I was unable to find the tube the installation sheet talks about, but got some clear-ish that fits the spike on the fitting; I think its for fridge icemakers or something like that.
Recently I read that the correct way to seal the hose is to heat it so it expands, then slide it over the spike. So maybe I should invest in the correct hose, but where can I get a roll?
Every couple of years, the aperture behind the fitting on the pump casing gets blocked with mud, so I have to take the tube off the spike to clean it out. That involves using a razor knife, and I need to be careful not to nick the fitting (creating a leak).
Time to do it again, the shower quits halfway through for a couple of minutes while it re-pressurizes.
Also, how do I fill the switch diaphragm & tube with water (air in there is too compressible)?
Do I have to turn the switch upside down, use a syringe to fill the diaphragm, then attach the tube & shoot water to fill the tube, then attach the tube to the upper fitting?
I see for sale "Low Water Pressure Switch Automatic Cleanout."
What is that? A way to purge the air bubbles out?
Why don't the two pipes to/from the well to the pump have valves, so you can work on the pump without losing the water in the standpipes?
