Geobrick
<misspelling in title: "Corrosion">
A local plumber did some rework on the plumbing from a water heater (part of the hot water circulation system) because there was a pin hole leak in one of the copper elbows. A few months later I noticed some corrosion where a T fitting and adopter come together. To me it's a sign of a slow leak at the fitting.
For the pros out there, is this a problem with the original work where you'd expect s call back or is this unrelated to the original work.
In either case, I suspect it wont be long before it becomes a bigger problem and should be fixed soon.
Let me know what you think.
