We are building a new home with 4 family members, 3 bathrooms, and 2 geothermal open loop systems, 4 ton and 2 ton, could actually go closed loop at considerably higher cost.
Well has been drilled at 222 feet yields 20-25 gpm. Well driller reccomended franklin constant pressure pump system. Contractor thinks the extra cost is a waste and wants to just put in a standard type sytem. I would like to maintain about 70 psi or more as the shut off pressure.
What size pump and tank should we use for a standard or cp system and is the cp system worth the added cost?? We are in central Indiana?? Pump pressure will go in basement and space is not a problem.
Also is the box store type softener as good as culligan or other types, we have fairly hard water in this area.
