Mdenglund
Hi All -
You have been of great support with past questions, so I thought I would give a few more a shot... My water alarm went off near my condensate pump (now wired into furnace, but I left alarm there, thankfully). Turns out I had a pinhole in the flexible copper right in front of the furnace switch... I cut the copper line (1/2'') and replaced the old vinyl tubing (5/8'' OD), but am nervous about a few things that I was hoping for insight on (photo attached):
Marty
- Having the copper connected to the vinyl with the metal screw clamps makes me a bit nervous - is there any better alternative? I have not had luck with compression fittings and flexible copper in the past (yes, likely user error).
- The takeaway line is always full of water from the pump to the ceiling - is this normal for it to remain full?
- Thoughts on what caused the pinhole in the first place? It was pushed against the switch / outlet box a bit, but I don't think it was enough to cause a hole? I am wondering if the acidity in the water is eating the copper line (which travels 20' through a completely finished ceiling). Anything I can put in the pump to prevent erosion?
Marty
