GrumpyPlumber
Licensed Grump
molo said:Note to Grumpy; Still Learning; In No Hurry.
"How would I have done this if I wanted to replace the cast and raise it the 1" i would have needed to get it above the subfloor? That's what I'll do next time!" NEXT TIME, Means NOT THIS TIME
I guess you didn't have time to answer the question, that's too bad. Perhaps somebody else can tell me about cutting and raising a CI Flange.
Molo..just kidding...couldn't resist.
Mind you...the following is not an easy task...plumbers "territory" here.
IF you really wanna do this right....get a drill, drill into the lead in the seam of the flange, then take something thin like a small screwdriver and pull it upwards, once you get a "bite sized piece" up you can grab it with channel locks and pull.
You'll likely only get small pieces at a time, but slow and sure it comes out.
Below that is the oakum...it's easier...use the screwdriver and pick it out.
Then put a new cast iron flange with a 4" hub in place, (they come with 2" hubs, but your pipe is already too low, based on the fact that the existing flange is below the floor.
brace it by either bolting, or screwing a piece of strapping to the top surface of the flange, with shims between the strapping and floor to hold it to the height you want it at.
Then wrap new oakum around the pipe at least 3-4 times, each time you go around once, pack it down mindfull not to be pushing the oakum past the bottom of the hub.
Remember the OAKUM makes the seal NOT the lead!
You will continue wrapping/packing until you have a 1" gap to the top of the pipe, being sure to push any stray strands of oakum into the hub and out of the way.
Finally, the "fun" part...you'll need a ladle, torch and 5 lbs of lead (plumbing supplier).
Find somewhere safe to sit the lead where it can't drip and melt/burn anything below, take the ladle and put it directly under the lead and position your torch so that it points down into the ladle as it melts the lead...you want to keep the ladle hot as well as the lead (glove on hand holding ladle).
once your ladle is full (NOT half...you want at least enough to fill that gap in the flange) pour it in.
Then you pack the lead all around the circumference of both the inner and out edges with a "packing iron"...technically you should have two seperate irons that are sized with a radius to each, but most of us plumbers only use one.(sins to confess...one day).
If this seems like alot, go with the flange extensions other members have suggested above.
