I shouldn't have said Amsoil. I use regular oil. And even regular oil will protect an engine far longer than the manufacturers guidelines.
It is not a conspiracy theory, it is a conspiracy fact. Pump manufacturers are not your friend. Yes they are lying and sticking it to you in ways you can't even imagine. Yes they promote using motors in all kinds of conditions including hot water. They are just not going to let you know that what they do to make it pump hot water will allow the same motor to work safely with a very small amount of cool water. That would mean a CSV cools motors much easier than their hugely profitable VFD's, and they are not going to say anything to promote a product that is disruptive to their profits. I have asked them many times if the motor is de-rated enough it can pump any flow rate of 140F, how much 60F water does it need to stay cool? See if you can get an honest answer to that question. Hitachi is the only motor company forthcoming and honest enough to answer that question for me.
I can tell you the answer to that question only because I tested Franklin motors myself, hundreds of times. The minimum flow through a CSV is designed to be at least twice as much as needed to cool a de-rated motor in cool water. Your argument is getting old. I showed you proof with two letters from a prominent motor manufacturer to prove my point, and you have shown nothing but the old rule of thumb guidelines that have nothing to do with a de-rated motor. Get a letter from Franklin stating that a CSV will not allow enough flow and they will disallow a warranty, or you have no proof of what you say. That would be really funny if they would write you a letter, as they sell things like that In-line 400 which works at much lower flow rates than a CSV.
