Collin
I am replacing a standard tub with a tiled shower. I understand the typical drain line width for a shower is 2". The current pipe is 1 1/2" and is in a concrete slab. The vent pipe is about 18" away, so I assume the stack is close, within about 2'.
Do I need to bust up the concrete and replace the 1 1/2" pipe with 2" pipe all the way to the stack?
If I do need to bust up the concrete, the copper supply pipes are also routed in the slab and come out close the drain. Do I need to take any special precautions? Are the supply pipes usually routed near the drain pipe? I'm worried about breaking one of the supply lines.
I want to do this right, but not do unnecessary work.
Thanks in advance. The guys at johnbridge.com recommended you.
Collin
Collin
