Cap or plug for 6-1/8 well screen
Bob Cooper
Columbia, SC
i have a section of 6-1/8 Well Screen that i need to cap off <-- not a well cap but seal it entirely. I'm fine w/a typical PVC "cap" or a rubber fernco like cap or plug of some type but i cannot find a supplier for this size. Everything i find is for 6". So the outside diameter is like 6 7/8 or so...but on the casing itself is says the ID is 6-1/8.
Any suggestions on where to look and hoping not to spend a fortune.
https://www.napcopipe.com/sites/def...620.1_SureFit-CertaLok-Slotted-WellCasing.pdf
SURE-FIT 82157810459
May be what you want. I expect it would be expensive and hard to find as a one-time thing.
The casing OD would be 6.9, and Fernco QC-7.00 says it will fit 6.44 to 7.25.
https://www.fernco.com/plumbing/residential-plumbing/qwik-caps
https://www.supplyhouse.com/Fernco-QC-7-00-6-Flexible-Qwik-Cap matches.
May be the same as https://www.homedepot.com/p/Fernco-6-in-Flexible-PVC-Qwik-Cap-PQC-106/100283362
VAWellDriller
Active Member
Richmond, VA
Its 6.9" OD and a good plumbing or well supply house will have a glue on PVC cap. If they wont sell to you call a local well driller.
Bob Cooper
Columbia, SC
Bob Cooper
Columbia, SC
Wow…thanks so much. I ordered the fernco part from supply house plus picked up a couple large ball valves. Great prices.
