Paulcmaine
Running a 4" waste line to the septic from the house. This is in Maine so we need as much depth as we can get for frost. We've hit one or two sections where a large flat piece of granite is in the way and extends laterally too far to just trench around it. It's only a few inches higher than our pipe grade so we have been breaking it up with the hammer drill which works but is slow going! My question is, what is the best way to protect our pipe with minimal depth? I don't want to chip out 4" of rock just to fill back with sand if there's any way to avoid it. Can I take a piece of 5" pipe and split it in half and use that to protect the 4" pipe from the rock? What about 1" blueboard? Is there an off-the-shelf product to do this? We're only talking about 4' total linear distance so cost is not really a concern.
One other question. On this island what they had on hand was sched 40 potable water well casing pipe. There is no reason not to use this for a DWV line, correct? I know you shouldn't use DWV for potable/pressure applications but my understanding is that if anything the well casing pipe is stronger than the DWV and will work just fine.
