Build up subfloor
DIYorBust
Active Member
Long Island, New York
There is currently a 1.5 inch differential between the subfloor in one room and the finish floor in the hallway. The finish floor for the room is expected to be 5/16th inch hardwood. That means I need to come up with about 1 and 3/16th inches to level the floor. I'd prefer to get the heights equal than use a transition, but no way is that going to cover 1+ inches.
So the question is, how can I most economically build up the subfloor? I can put plywood down, but 2 layers of 1/2 inch plywood is going to cost like 3 bucks a square foot! Should I tear up the subfloor and shim up the joists? Doesn't seem easy. Is there some other material I could use to underlay the floor?
This is not directly a plumbing question, but it's one that comes up in plumbing projects, so I was hoping you folks would have some thoughts!
DIY
wwhitney
Berkeley, CA
In my limited experience (oak), 3/4" hardwood is not particularly more expensive than 5/16" flooring, for a given grade. So maybe just put down a layer of 3/4" plywood, then 3/4" hardwood.
If the 5/16" thickness is fixed, you could put down one layer of 1-1/8" plywood. That stuff is really heavy, so a layer of 1/2" and a layer of 5/8" might be easier to install.
Cheers, Wayne
DIYorBust
Active Member
Using 3/4 inch wood flooring would be a different issue because of the style of floor, and pieces for the border. so it might be difficult to do that in 3/4. 1 and 1/8 plywood is available at lowes for 1.90/ sq foot! That appears to be the winner so far.
DIYorBust
Active Member
Yes but the border is 3/8ths. I've could get the border backed with 1 1/8th plywood and then get the 1.5" oak and try to sand them smooth, but would I save any money?
wwhitney
Berkeley, CA
Just providing the info in case you didn't have it. Now I'm curious, what kind of border is this?
Cheers, Wayne
