Hello all:
I had a Rheem natural gas water heater installed 3 years ago, to replace a rental tankless heater. This new heater has performed flawlessly. However, for about 5 months, every bath results in smeary black specs being deposited on the bathtub surface after it is drained. These spots do not clean up easily. As the tub is 8 feet from the water heater and draws the most hot water (my wife runs baths very hot) of any appliance in the house, I inspected the inlet strainers on the tub's faucet. Hot side was caked with black rubbery bits, cold side had no black debris. The tub's aerator also had a bit of black debris lodged in there as well. This problem is not appearing anywhere else in the house. I drained the water heater and strained it as it was dumped to an adjacent drain, no black debris, a disappointing finding. House is plumbed with pex + brass fittings, there are no flex hoses anywhere between the water heater and the tub. I know because I installed the tub during a reno a year ago.
I still suspect some black elastomer in the water heater is degrading. I used my magnifying lamp as I cleaned the tub's hot side strainer out. It had a rubbery texture, it was not greasy, just little black chunks. I confronted Rheem, they responded with a canned blurb about water chemistry.
Opinions anyone ? I think something in the water heater is failing, and it's under warranty. Any other tests/inspections I can do to conclude with high confidence the water heater is the culprit ? Any experience of water heater failures causing my symptoms ?
Sorry for lengthy post, want to give you decent background to work with. I'm really stuck on this, and need your help.
ddton
ddton
