sump pump
sorry it took me so long to reply
te Zoeller pump itself is about the best motor and pump
you can buy.. the only problem with that brand is their
switches are always a problem when they are built into the motor...
MANY pumps are built that way and when they fail you are screwed.
buying the pump only and buying a separate
VERTICALMASTER Switch that goes on the pipe
is the best combination and is very easy to change inthe future..
if you buy any pump whhere the pump and the switch are
integrated into one wire to be plugged into the wall ,
if the switch fails you , you cant get the pump
to come on........and you flood out...
With two wires comming off the pump, the motor plugs into
the back side of the switch , then it all plugs into power....
If this switch were ever to fail you
you can always unplug the switch and then plug the
pump directly into power and keep the pump working
untill the calvary arrives....
