Bathroom remodel.Tub removal and shower install.
Redwood
Big difference between a 4" curb and the sides of the tub...
Code says showers are 2" it is what it is!
Florida Orange is correct the 2" is an underground minimum and it should be very close.
The next thing we were going to hear was can I plut my shower on a pedastal and run automotive radiator hose over to the existing drain...:eek:
How far off was I?
There is a right way and a wrong way.
Personally If I'm not doing it right I don't do it!
If you are going to do Pig Slop Plumbing work you don't need to ask me how to do it...:cool:
AZoutlaw
Big difference between a 4" curb and the sides of tha tub...
That is the plan now!! Thanks.:D
I totally understand quality work. I am just trying to figure out code logic.(Seems impossible)
Redwood
Your tub may even have a 2"trap with a 1 1/2" adapter where it connects to the trap. In that case it only has to move to where the shower drain will land.
AZoutlaw
So what would the proper way be to remove the concrete without damaging other pipes?
FloridaOrange
Plumbing Designer
SW Florida
With a concrete saw that you can rent. For a small area I don't know if it would be worth getting a wet saw - dry saws throw a lot of dust in the air but you can tarp off a room or area without too much dificulty. You set the blade to be just below the thickness of your slab, cut and then lift out as a peice if you're lucky or you bust out a sledge hammer and/or chisel.
AZoutlaw
CHANGE OF PLANS!!! Putting the tub back in! Reusing existing plumbing. Yeah!:D
AZoutlaw
yeah seriously. To get to the main drain it looks like i need to get into the adjacent bathroom and that is way too much work.
AZoutlaw
I talked to a friend of a friend who is a plumber and he thought the same thing.
Maybe i can try the concrete cutting. what are the chances of damaging the other pipes.
Here is what I am looking at. Maybe it will be easy but I am over nervous.
Redwood
I'd start digging that dirt out of the existing hole following the pipe and see if the trap comes into view...
nothing to get scared about...
AZoutlaw
All busted out. I see the p-trap it is 2". The vent is only 1.5 and runs into the 3" stack to the roof.
Now if I replace the p-trap with a new one(the only place to get a cut and fit a new piece is between the trap and the main line) and run 2" to the drain, should all be good?? Also can I make the p-trap go deeper so I can fit my shower drain more easily??
Redwood
You got it Bud!
Weren't that easy!
Thanks for not wimping out on us!:cool:
Now all you have to do is bust a trench to the new drain location.
AZoutlaw
Thanks for the push. Believe me I will need some more of it down the road.;)
vent
One question that has not been asked is that you stated the overflow had a vent, or at least that is what we took it to mean. IF so, what size is that vent, because some homes have the air conditioner condensate drain connected to the tub drain, and if you have that situation, you WILL need to do something about it.
Now that you're getting the drain squared away, be aware that the best place for it is centered in your new shower, not close to one end or edge.
For some help with building the tiled shower, check out www.johnbridge.com. Check out www.schluter.com and review Kerdi. A good way to build a shower.
AZoutlaw
got the drain all piped and it is running down towards the main line a hair more that 1/4 per foot. The drain flange fits nice and level too. Now how much perimeter do i need to leave around the drain line going down? Is it okay to replace my concrete i took out?
AZoutlaw
IT is a 1.5" vent that runs into the 3" stack.
