Bathroom Makeover
NoviceDIY
I am redoing the bedroom bathroom and need to replace the wall flanges that are badly corroded. I would like to do this without having to remove the shutoff valves. Does anyone make aftermarket wall flanges with a slit that can slip over the piping?
escutcheons
There are hinged ones, but they look tacky. One company makes a "spiral" plastic one the slips over the pipe, but I haven't been able to find it again.
Solsacre
Arkansas
tacky tacky tacky.....
If your going through the expence of re-do'n your bathroom, invest in one of two options...
Replace the escutcheons yourself: If it's galvanized (I hope not) just screw them off. shouldn't take more than two hours. :p if Copper there are several tools that will remove the comp. nut or you can work it gently off with a pair of chanal locks.... grip the nut from the outlet side and work it back and forth.
or
When your Paint is dry call in a good plumber: any plumber should be able to replace the escutcheons (2 lav 1 toilet) withing the 1 hour min. Money well spent for a good clean finish job.
If your going to do it do it right. good luck
dances-with-pumps
