Are 2 Quarter (90) Bends Allowed In Horizontal Drain Line?
herynkc
Portland, OR
Im doing some renovations in my basement. I am in the process of both relocating my washing machine / sink drain line and digging a hole to pour a spread footing for a column which I am moving. The footprint of this footing interferes with my current drain line path, therefore I have redesigned the drain line (as pictured in my drawing). The photo shows the current layout of the drain line. It looks like they have incorrectly installed a sanitary tee in place of a wye or combo wye. So is it a bad idea to have those 2 90bends back to back? I dont want to have a cleanout between them, nor do I think that there is room to do 2 45 bends since my furnace is on the other side of my proposed drain line to washing machine and sink. Thanks for your help
I have drawn on the photo in green to layout my proposed redesign, black lines show uncovered existing lines, red is the square area I cannot be below.
herynkc
Portland, OR
The sanitary tee is actually 4" reduced down to 3" lines everywhere else.
So im eliminating the straight run coming off of the current sanitary tee, so do you mean a wye and a 45 bend? A double wye gives me 3 offshoots, I only need 2.
herynkc
Portland, OR
Thanks for all your feedback. Im going to go with a wye and a 45.
Upon excavating the rest of the area, Ive found a large void beneath the slab. Is this common in older homes? Any plumbers seen this?
Got critters in there? When pouring a slab originally, that area had to be filled in, or the concrete would have filled it in.
herynkc
Portland, OR
I ended up installing it like this, a wye with a 45 and a 22.5 on the end:
