This is a half-bath. The question is whether the W.C. is properly vented. I drew a 3x3x2 sanitary tee to vent the 2" straight up through a wall.
As can be seen, I piped the lav drain so as to come into the 3" drain downhill from the W.C.
And how about this? I drew a sanitary tee for the joint where the lav drain will connect. Is this OK or do we need to use a combo wye and tee for this (very common) connection at a lav drain?
