Alternating Pumps vs. Primary and Backup
YTJ79
New York
I have an active sump pit attached to a footing drain - goes off 3-4 times per hour for ~20 seconds each time. Right now I have 2 Hydromatic SKV50 pumps with SJE Rhombus floats. It is currently wired with an alternator so they switch back and forth each time the pump goes off. The guy who is likely to service this system for me going forward suggested that instead I use a primary pump and a backup pump, the float for which would be set at a slightly higher water level than the primary pump to only go on if the primary fails. His rationale is that this would make the system a lot easier to maintain by avoiding all the wiring required for the alternating feature. He also suggested changing the switch to something that wouldn't ever get stuck (can't recall what, ball float maybe?).
I had called Hydromatic in the past and they said it was good that both pumps run regularly, so I am a bit concerned about having a backup that may not run for a year and then doesn't work when called upon. Our exterior footing drain is attached to a pit in the front yard which is not easy to access, so it would be hard to test the backup in between the annual maintenance calls. Does anyone have any strong opinions on whether having alternating pumps is worth the extra wiring complication vs. just a primary and a backup?
Thank you very much!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
With water well pumps I prefer the primary/secondary type set up over an alternator. With an alternator you wear both pumps out at the same time and basically do not have a backup. But you do need to exercise the secondary pump once a week or so. I use a 7 day programmable timer like a sprinkler timer from Rainbird, Toro, Irritrol, etc. But instead of operating a solenoid valve, the timer operates a relay. In your case the relay could have one normally open and one normally closed set of contacts. That way you set the timer for once a week to switch primary/secondary pumps for just a couple hours. This will keep your secondary pump exercised without wearing it out. So when the first pump quits, the second pump doesn't have nearly the hours on it and will be a good backup as needed.
YTJ79
New York
Thank you!
you
