Dja4260
Hello everyone.
I recently purchased my forever home just outside of Greenville SC. It's my first home with a well system. Previous owner said everything is original to 1994.
Current set up:
Well (per tag on casing)
Casing depth: 36'ft
Static water level: 40
Depth 180'ft
Diameter: 6 1/4''in
Yield: 70 gpm
Pump is unknown but 3 wires exit the cap (red, green, black).
Water tank:
Amtrol Well x-trol 44 gallon with 40/60 switch. Located in the basement of a 2 story (above grade) home.
The pump currently turns on at 50 psi and shuts off at 68psi and I have a very noticeable loss of water pressure until pump kicks on, which I find to be very annoying. I did try to further adjust the 40/60 switch and managed to ensure that the pump stayed on for 1 minute at minimum to reduce short cycling. Obviously things are out of wack and the pressure switch should be replaced.
I'd like to be proactive and educated on what's best for my family when the time comes to replace these items.
My wife and I have 3 young children and 4 bathrooms. We don't water our 4 acres and fill up kiddie pools often!
I was looking at large well tanks, then read up on CSVs.
I'd appreciate your insight on the brand/HP of pump, well tank or CSV. If at all possible, I'd like to have more water pressure. House is unfortunately currently piped in CPVC.
Thank you all for your help.
Current set up:
Casing depth: 36'ft
Depth 180'ft
Diameter: 6 1/4''in
Yield: 70 gpm
Water tank:
