Veronika KD
Hello,
Our 3 handle trim needs replacing and I do not know what to buy. The original bras/porcelain handles would hit each other (the hot and diverter) making it difficult to turn the water off without problems. I have replaced the hot and diverter handles with a cross arm handle by PartsmasterPro that d0 not fit great (a bit lose on the stem) but we were able to turn to water off without handles blocking each other.
Those PartsmasterPro handles have reached end of life and I was hoping to replace all handles with something that fits more like the original Pfister trim (i no longer can locate the two Pfister handles i removed).
Plumber i called to replace the valve told me the valve was Pfister so i suppose the trim is pfister as well. When he replaced the hot water valve it changed the direction in which the hot water handle would open the flow of water- prior to valve change it used to open the flow of water in clockwise direction, after the hot water valve was replaced both hot and cold water open in counterclockwise direction. the plumber told me the replacement kits for this type of valve & trim are no longer available for sale.
thank you!
Veronika
thank you!
Veronika
