John Vegas
You may also want to order the 90 degree adapters for thew 7000 to make the installation a little easier.
What exactly is the purpose of a 90 degree adapter? I assume it allows the back of the softener to have a vertical connection rather than horizontal? I imagine that only make the installation easier if you use flexible connections?
If you have 1-inch pipe, and the Fleck is a 1 1/4" valve, it is worth using a 1" to 1/4" inch connection? Those flex pipes get a bit pricey. Is it a problem to do a 1" to 3/4" on (water pipe) the Fleck (3/4") or should I stick to the 1" (water pipe) to Fleck (1 1/4") ? Actually looks like I would need to do 1" (water pipe) to Fleck (1") because I don't think you can get 1" to 1 1/4" flex connections.
Thanks, JS
