1900"s crawfoot tub Mueller faucets
Marlee
Quebec, Canada
Hello,
I live in a historic 1890's home in Canada and want to replace my clawfoot tub faucet with one that has a hand shower. It's in perfect order, not even a small leak and it looks great the manufacturer says Mueller so 1908-1920 maybe?
The centers are 3 3/8. I've seen one on
https://www.vintagetub.com/strom-plumbing-handshower-clawfoot-tub-faucet-p0154qc-s.html
that I like but I don't understand the whole supply line recommendation? Could it be that this new faucet will not fit with my old pipes as far as diameter is concerned?
Thank you for any info you can provide.
The connections should be the same as your faucet and should attach directly to it once the faucet is installed. One question I would have is that it specifies that it has a vacuum breaker/backflow preventer, but does not say if that applies to the hand held and the spout, or just the handheld. Typically, that type of bathfaucet is NOT legal because the water outlet is below the rim of the tub. In any case, the way the pictures were taken, it would seem that any vacuum breaker on the faucet itself would still be below the tub's rim which would make it unacceptable for any tub. The #RM376-cp would be a properly installed leg tub faucet with handheld.
Marlee
Quebec, Canada
Thank you so much for your reply hj I really appreciate it :) I would prefer the look of Item#: RM375-PN do you think it is also appropriate and legal?
Yes. The determining factor is whether the spout is above the rim or inside the tub. The RM375 has an elevated spout to make it legal, but MORE important, safe.
